My Jenn-Air dishwasher will not run.
This started two days ago. Originally the number on the panel would flicker and it would start running then stop. I then would have to use the DRAIN to drain what little water it did dispense. After a few times, it finally did wash.
The rinse button is working and would rinse. As of today, the light on the panel did flicker and it did dispense water, but now it is making a clicking noise and will not proceed with the wash cycle. And now the DRAIN will not work. It is less than 5 years old… I am really getting disappointed with my Jenn-Air appliances. I had problems with my oven about a year ago, now the dishwasher. :mad: HELP IF POSSIBLE!!!
check the door micro switches in door latch
