My Kenmore Ultra Wash with Quite Guard has a flashing Air Dry light that I can’t seem to reset. I’ve tried everything that i’ve seen posted on several sites. Maybe because they are not related to my model. Is there some way of resetting the Air dry light? The lock is not blinking. It will not let me do anything. Depending on what button you push the quick rinse button flashes aswell. PLEASE HELP:confused:
Sounds like that key pad got stuck in the depressed position. The correction is to replace the control panel. If you need the correct part number, post the color of the control panel.
