Dishwasher won't drain
need help on what to check so it will drain
Model GSD3800G00CC
Need more info, can be many things
What does it do?
Does it try to drain re: motor running etc?
Have you checked anything?
Does the drain solenoid activate? Behind the kick plate on the motor/sump assembly. left hand side.
