Dishwasher won't drain
I can hear the motor hum during the drain cycle but the tub does not empty. I think It may have an obstruction. How do I remove the lower wash arm assembly so I can check the pump? Also the pump and motor both seem to work fine during the wash cycle.
The first thing I would do is remove the bottom panel and check if there was a leak through the pump seal, causing corrosion to the motor.
Here are the break down diagrams for the Maytag dishwasher Model MDBD820AWB
