Dishwasher won't complete wash cycle. Timer stops
:confused: PLEASE HELP! Start the timer dial on pots and pans or normal wash. The timer will run for a while. It will fill, wash, drain and refill and start to wash and then the timer stops. The timer dial has to be operated manually for each stage to finish the whole wash cycle.
If the dishwasher is turned off and not run for awhile the timer will work in any stage of the full wash cycle and the drying stage. It will eventually stop.
The boost thermostat has been replaced and that hasn’t made a difference.
Thank you for your help.
Does the Heating Delay light stay On when the timer stops?
Here are the breakdown diagrams and Replacement parts for MAYTAG DWU9202AAE Dishwasher - Undercounter | AppliancePartsPros.com
Yes the heating delay light stays on when the timer stops. I tested it this morning. I started the dial on NORMAL WASH and it kept working all the way through LIGHT/CHINA The timer stopped and I let it sit for a while and nothing happened. I opened the door part way and let it sit for about 5min. Shut the door and the timer dial started working again and the washer started going again. The heating delay light came on. I checked to see if the timer was running and it wasn’t. The heating delay stayed light on for almost 15 minutes then went off. The timer started up and the dish washer ended that part of the cyle and the quit. The timer was not running. I opened the door and there was still water in the washer. I helped the dial manually to finish it up.
Is there any other trouble shooting I can do to figure out what is wrong with the dishwaher? Thank you.
Sorry for the delay.
Check the heating element for continuity. If the heating element is good, replace the timer.
The Kobe Bryant Shoes is going to be released right now. This style is screamed out the layout of 89 Flight era. It will remind you the times and places of the 89 flight industries. Kobe shoes are designed to give you the most comfort and stylist outfit. Excellent outlook with right choose of colors makes this sneaker about perfect.The new series ******** Shox got a new family.Actually to welcome the spring, you should have a pair of this I think. You will remain fresh for all the day. This series of cheap ******** shoes are a new craze and thats why you need to hurry to get a pair of this.It is colored with white, grey and metallic silver with some nearest shade of those colors.
:slight_smile: Gene, sorry I didn’t reply sooner. I didn’t have a chance to check the heating element until this morning. I haven’t used a ohm meter very much. I set the dial at 200k and got a reading of 22.3. The manual says that it should have a reading of 22. I am assuming that the element is good and am going to order the timer. Thank you for your help! JEV.
JEV,
You have to set the ohmmeter on lowest possible scale.
[LEFT][COLOR=#000000]The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
[/COLOR][/LEFT]
I went back and checked and found out I had the scale on 200 not on 200k. The meter read 22.3. So I’m thinking I should order the timer.
Yes, order the timer and keep us posted. Good luck.
:slight_smile: Gene. I finally got around to installing the new timer switch on Saturday. I ran the dishwasher starting with the pots and pans cycle all the way through heated dry with every button on. It works perfectly! THANK YOU VERY MUCH!
You are welcome. I’m glad you were able to fix it. Thank you for the feed back.
