dICHWASHER QUIT RUNNING WITH ABOUT 2 INCH OF WATER IN THE BOTTOM. DOESN’T APPEAR TO HAVE ANY POWER AS NO LIGHTS WILL APPEAR. BREAKER HASN’T KNOCKED. ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED. THANKS
Could find no info using the listed Model Number
If you do not have a wiring diagram, which I probably will not be able to find on the internet, remove the kick plate it may be taped to the back of the kick plate or bottom of the tub.
Usually no apparent power is due to the door switches.
Sometimes a switch breaks, sometimes the door latch breaks and sometimes a switch just needs adjusting.
Also some units have a fuse on the control board.
The door switch checks good as far as getting power but I dont know if it can be adjusted or not. Plus I cant find a fuse. Where should I look? Its not on the inside of the panel could it be behind the touchpad. I couldnt figure how to check behind it. Your help will surely be appreciated. Thanks
Fuse will plug into the control board either directly or by a couple short wires
Here is an example Item 6 in Section 1
Model GU1200XTLT3
Here is a good link which may help you diagnose the problem
http://www.applianceaid.com/dishwash.html
