my dishwasher will not run.all light’s work on panel.and is not flashing any code’s.thanks
Replacement parts for WHIRLPOOL GU1100XTLB1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet which should help you troubleshoot it further
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Could be a door switch is not closing or it’s contacts are shot.
