Dishwasher will not run no sign of life
change control panal about a month ago. check out power to unit ok. checked door latch and micro switch ok. diagram shows afuse kit part # ap-3178588. can this fuse kit be the problem and where is it located? please advise pete pirrri.
Replacement parts for WHIRLPOOL KUDS01IJAL1 DISHWASHER | AppliancePartsPros.com
Fuse is Item 6 in Section 2.
Could be on the board or on a small harness.
Be sure to replace/install the harness that comes with the fuse as that is often the cause of it blowing.
