Dishwasher timer
Panel shows cycle time as it counts down. At certain minutes display stops going down and just keeps running at that time. Am I correct in assuming the whole control panel would need to be replaced? I realize that the dishwasher is over 10 years old and if it is the whole panel, a new one might be the asnswer.
How long time it stays at that point?
How warm is the water inside the dishwasher?
[quote=Gene;231463]How long time it stays at that point?
Gene.[/quote]
I have waited at least 5 minutes and it doesn’t change. Water is very hot, and if the cycle is adding water, it seems to keep adding. (Minute 52) I first noticed this because the dishwasher started to leak, and it had never done that before. Seals are good. I ran a different shorter cycle to see if I could avoid that specific “minute”, and no leak, but a stall at a much lower minute happened(6). Do you think that it is heating the water and holding for that?
Yes, I do. It should heat up the water and the temperature hold until it reaches the thermostat temperature or it can be up to an hour by default. I could not find the tech sheet for this model and can not tell you what is the exact temperature. It can be from 135°F and up to 160°F.
Thanks, I’ll watch for the water temp and see how the timer changes.
P.S. Incoming water suppose to be about 120°F.
