Dishwasher sprayer arms will not spin
[QUOTE=ugad52;420289]I have a GE Dishwasher Model # PDW7800J10BB
Do I need to clean a filter located in the door also? Thanks for your help![/QUOTE]
Yes, if you meant the vent (#815 on the diagram) and it is clogged.
Here are the breakdown diagrams and Replacement parts for General Electric PDW7800J10BB Dishwasher | AppliancePartsPros.com
[quote=Gene;61963]What is the complete model number of the dishwasher?
Gene.[/quote]
HDA2020Z05BB
and there is a part inside the white drain pump housing that is flat on one side and curved around the rest-it’s rubber gasket edge is wavey/ruffled and it is on the side of the drain solenoid—checked for debris in arms, in inlet valve-cleaned diaphram and screen/cleaned grater nut, checked bottom of unit----tower rises and water flows in arms----should I just buy whole assembly and will that part be in it???
Hi Tom,
I’m afraid I did not get clear what is wrong with your dishwasher.
Here are the breakdown diagrams and Replacement parts for General Electric HDA2020Z05BB Dishwasher | AppliancePartsPros.com
