Dishwasher repair
We woke to find that the washer had not run, did diagnostic ended up replacing control board and fuse. Still won’t turn on, high temp scour flashes, run test and normal light flashes also. Don’t know what’s up.
Replacement parts for WHIRLPOOL DUL300XTKT0 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
You may have a stuck key, the tech sheet has a test procedure.
Also check that the keaypad connectors are OK
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Thanks! I will try that. Was trying to avoid a service call, but may pay more in the long run possibly.
