Dishwasher problem
I have Quiet Power 3, GE dishwasher that is not getting my dishes clean. I have no idea what is wrong with it. It leaves a white residue on all the dishes and is clearly not getting the food off of them either. I don’t know what to check, or how to fix this? Does anyone have any ideas? It is only 2 years old so it shouldn’t be broken yet!
Very likely there are hard water deposits built-up in the dishwasher. You can find how to clean the dishwasher and improve performance in one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/12961-how-do-i-take-remove-strainer-clean-heating-element.html#post37989
Have you replaced your water heater or just changed the temperature lately.
If Gene’s suggestions do not work try dropping the temperature a couple degrees. If that does not work try raising the temp some.
Drain some water out of the hot water tank, use either the pressure relief or the bottom drain.
