If sounds like you have a latch problem - the latch does control which display lights are showing. You may have gotten the latch in the closed position when the door is open. If this is the case the lights on the front of the door will light and not the timer and lights on the top. If this is the case you will need to remove the outer door to access the latch and reset the latch into the correct position. Once the latch position is correct your door top light will work when the door is open.
The Beep
Turn the unit off and while holding the right “Cancel Drain” button turn the unit on. The “Cancel Drain” button lights will now be flashing, press the right button to scroll throught he beep volumes. When off or quiter shut the unit off to save the setting.
