My name is Randy and I am trying to find out what could be possibly wrong with my dishwasher. It experienced a burning problem. I replaced the main PCB and the Power PCB, but still, no power. What could be causing this problem at this point? Could you please help me?
Check for 120 VAC at the power outlet for the dishwasher. If the dishwasher is hardwired then you have to call an electrician to find the right circuit breaker for the dishwasher and check the voltage.
By the installation instructions any dishwasher must be connected to a separate circuit with its own 15amp or 20amp house circuit breaker. Usually all breakers are in a breaker box.
Hi Friend,
This is Randy again from yesterday. I have power coming from the wall outlet to the unit. but voltage on the main board is less than 2 volts. My question is, Does dishwashers have thermal fuses? I not sure about this because if so, that would be the next thing i check. Thank you.
Hi Gene,
I think that i will have to take a picture of the schematic of the unit and try to see what else could be causing this power drainage. However, I want to say thank you very much for the help that you have provided me and I want to wish you the best. Thank you.
There are no fuses in the dishwasher. Problem can be a bad noise filter (#A160 on the diagram), a bad door switch (part of the door latch) or a bad on-off power switch which is a part of the display board.
