We purchased the dishwasher about three years ago. The dishwasher flashes constantly on normal wash, sometimes all of the lights will come on as well.We have to press the cancel button a few times and occasionally it will clear it and then you can run the dishwasher. We have replaced the board, replaced two switches, had a professional in, and still we cannot solve this issue. Please if someone can solve this mystery please help us.
I am assuming the board you replaced was the control board
It could be the keypad.
Try the below, if that does nothing then check it with a meter as per the tech sheet
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
