Dishwasher not working
dishwasher started and was running, then stopped in the middle of the cycle and shut off. Unable to get it started again.
Replacement parts for WHIRLPOOL KUDS25SHWH1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208051291.pdf
As always when a unit is dead check that the breaker has not tripped.
Next check that the unit is getting power where it is hooked to the house wiring.
Several months ago had a run of people where the connections in the wire nuts were bad.
Next would be the thermal fuse (Item 22 in Section 3)
Check it with a meter.
If blown be sure to use the new harness.
Note: this fuse can blow due to temperature or current, so check the other components for resistance especially the wax motors if your unit uses them.
If OK next would be the door switches.
