Dishwasher not starting
dishwasher would not start. when turned on and pressed STRAT button the, the “NORMAL” and “SOAK & SCOUR” ligts turn on but the dishwasher does not start? Any suggestions?
Replacement parts for WHIRLPOOL GU2548XTPS7 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
Sounds like you may have a keypad problem.
Also may be the control board
try to run the diagnostics.
Try the below connector cleaning
Check the keypad with a meter as both these buttons use P1-13 see the Page 2 of the tech sheet
Connector Cleaning
