Dishwasher not runniing
Has been making a loud noise while washing but still worked…Today the green light under “clean” is flashing but it didn’t wash and when I try to start it again it won’t do anything? The green button under clean just continues to blink…
The Clean LED blinking 7 times means the control senses a fault in the temperature rise during the heating cycle.
The electronic control could be reset by initiating a service diagnostic cycle.
While the dishwasher is inactive press the Heated dry, Normal, Heated dry, Normal keys within 6 seconds.
If it happens again then the heating circuit should be diagnosed.
Regarding a loud noise I would recommend to check the pump chopper for a foreign objects. You can find the instructions in one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/2903-whirlpool-dishwasher.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2400XTPT3 | AppliancePartsPros.com
A clogged sump can actually trigger the clean light flashing.
