My dishwasher stopped getting water in..I can hear the motor cranking and it spinning inside but it is bone dry. I’m not sure what to do…
[FONT=Times New Roman][SIZE=3][COLOR=#000000]The first thing you should check is the float on the right front corner of the tub (#305 on parts breakdown) it could be stuck in the up position. If so clean it and the shaft it sits on it may start working. [/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman] [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]If that isn’t your problem make sure water is coming to the washer. [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]If you have water and the float is not stuck the water inlet valve is most likely the problem. [/COLOR][/SIZE][/FONT]
