Dishwasher not drying
Can you tell me how to test the heating element? Can continuity be checked inside the unit or under the unit. Where can I test to see if power is being supplied to the element? I assume there is a relay to handle the power between the timer and the element. Can you confirm and give the location.
Your model number does not come up, please check it.
Also what is the make.
Model Number Locator
