The dishwasher goes thru the cycle but when i open the dishwasher the detergent packet is at the bottom of the dishwasher or sometimes its half in the soap dispenser and half at the bottom.
The water is hot and it sounds like it originally did when i first bought it. Dont know what is wrong with it. Can anyone help??? Thanks a bunch!!
[quote=hmaese;328158]The dishwasher goes thru the cycle but when i open the dishwasher the detergent packet is at the bottom of the dishwasher or sometimes its half in the soap dispenser and half at the bottom.
The water is hot and it sounds like it originally did when i first bought it. Dont know what is wrong with it. Can anyone help??? Thanks a bunch!![/quote]
Hmaese,
Recheck and make sure your water in the tub is 120 dgrs at the first fill / wash cycle.
Make sure you don’t have anything large blocking the detergent cup area in the front of the racks.
You will need to check and make sure you have the proper amount of water in the tub bottom when the water stops filling, 1/4 to 1/2 in. above the filter plate.
If all those check OK and proper. Try a different or new detergent, some chemicals go bad in the box.
Good Luck,
