Dishwasher no start
Maytag dishwasher no start, all functions on touch pad assy change lights accordingly except when you push start button nothing happens board is not burnt although i suspect it is bad i appreciate any input. Thanks
Replacement parts for MAYTAG MDBH945AWW Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026393.pdf
Try running the diagnostics.
Could be just a bad start switch. Check it with a meter, see the tech sheet.
May even be that the panel (keypad) to control board has a dirty connection, try the following cleaning procedure.
The usual way to troubleshoot this is to check the keypad, if it checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
