Dishwasher is stuck on washing status--buzzing NOT washing
I have a whirlpool dishwasher model 8575637. The other day I went to close the door and without touching a button it was on washing status, normally I’d have to press the continue button. I tried to cancel the setting, nothing happens, just a lite washing status. If I keep the door open the buttons go blank, when I close the door same thing lite washing status with a buzzing noise inside. So I cleared all the racks to check for a fork or spoon caught somewhere, nothing. I flipped the breaker outside in hopes of resetting the system, nothing. The buzzing and lit washer button continue for about 5 mins with the door closed and then will shut itself off needing to flip the breaker outside.
Any advice or tech support out there , I heard there’s a button sequence to reset the system.
Thank you for your anticipated response.
If the dishwasher is less than a year old then it’s still under the warranty and you have to call Whirlpool for service. The model number you posted is not valid Whirlpool model number. Verify and repost it if you need any further assistance.
Ok Thanks,
DO I just call any whirlpool # and ask them to come out and fix it?
Oh and I think this is the model #
Du1055xtss2
Call customer service at 800-253-1301 and they will put you in touch with a service company in your area.
Nat
