Dishwasher is full and nothing is happening
Yeah!!
So the dishwasher is full and the door latched. It filled and started washing. Then it stopped. No lights will come on on the front of the unit. Checked the breakers and all is okay there. Nothing blocking the arms in the unit. Is there a circut breaker on the unit itself like a garbage disposal? Thanks John
Update: With the door open the lights have started to flash on the front. However, when I close the door and it latches, the light stop blinking.
This is a Amana SofSound ADB1200AWW
Remove the inner door panel and check the door switches. Check if 120 VAC is coming to the switches (one is for the hot line and another one is for the neutral). Use the wiring diagram for the troubleshooting.
