Dishwasher hangs at water heating cycle
my dishwasher will fill, but not proceed past the “Heating Water” cycle. Pump seems to work to drain upon cancelling wash, but will not proceed to the wash cycle.
Check the heating element, If its not working OR the water is not HOT enough, It will NOT advance!!!
is there more than the one heating element listed in the parts list as “heating element”?
Here is your parts breakdown
Model KUDS230BAL0
Item 1 in the “HEATER” section is the one used to heat the water.
The other one is for air dry. See “BLOWER” section
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209742248.pdf
