the dishwasher cycles thru, but does not generate heated water. the sanitize cycle only creates luke warm at best. thanks for your help
Remove the kick plate
Remove one wire from the heating element
Measure it for continuity
If OK
Remove one wire from the thermostat and measure it for continuity, should be 0 ohms (I think)
