Dishwasher flips circuit breaker
My dishwasher has a short because it flips the circuit breaker when the on and off button is pushed. I have replaced the user control panel. What are the potential problem areas to look at. Thanks.
The first thing you may want to do is plug the dishwasher in a different power outlet. If it will work then the problem is a bad circuit breaker.
If the breaker is fine, remove the bottom panel and check the power cord connection to the dishwasher. Next step is top check the door switches and the push button switch. The wiring diagram is on the bottom of the lend hand menu on the diagrams.
Here are the breakdown diagrams and Replacement parts for Bosch SMU7056 US/09 (FD 7210-) | AppliancePartsPros.com
