Dishwasher Door Jammed
I took the door apart today and had trouble figuring how the latch “link” fits in the latch mechanism when reassembling. I thought that I had it in correctly, but when I closed the door, it won’t open again.
Any advice??:frowning:
The only way is to pull out the dishwasher unhook the latch and then unscrew the door panel. If the unit is secured good in the hole your out of luck. Your going to have to brake the door lock.:eek:
You may be able to slip a putty knife, or butter knife under the door latch and pry it off. Worth a try.
