Dishwasher does not drain
dishwasher does not drain completely. removed and cleaned. unit drains out of cabinet. drain line open. nothing obstructing check flapper.is pump the problem?
[QUOTE=jerry2083;234476]dishwasher does not drain completely. removed and cleaned. unit drains out of cabinet. drain line open. nothing obstructing check flapper.is pump the problem?[/QUOTE]
I have the same problem. Replaced the drain pump. Did not fiix the problem. Suspect the controller.
Thanks wonder how u check controller?
