Dishwasher Dead
My dishwasher is Dead. It stopped working just after the rinse cycle. Because the dishes were clean. There is water is still down at the bottom of the washer. The control panel is dead. I have check the thermal fuse. Reads 1 ohm. I did check the latch switches. They have continuity when switch is made and none when broken. Anything else to check before I order the control board? Also is there a way of checking the control board. Also I do have power up to the latch switch in case you were wondering. Thank you for you time. Help:(
Maurice
Maurice,
How did you check it?
According to the wiring diagram there are two switches. Did you check for 120VAC between them?
