The child lock light remains on and blinking at all time thus not enabling us to access the other controls. I can hit the energy saver dry key and the light will go off then back on. If I hit the cancel button it will drain and the child lock light blinks again. At no sprecific time a cycle will start and fill with water, then stops and child lock light blinks again. If I am able to start a cycle it will fill then stop and the child lock light blinks again. Any help would be appreciated.
David,
Most likely the control detects a stuck key(s) on the control panel. The correction is to replace the control panel. If you need the right part number then post the color of the control panel.
Here are the break down diagrams and the parts list for the Kitchen Aid dishwasher Model KUDS25SHBL0
