Dishwasher control lights out and dishwasher stopped working
The dishwasher has stopped functioning. There are no lights on the control panel and there is standing water in the base of the unit.
I had an earlier issue with the touch panel and it was replaced. At that time the control panels lights would flash.
This time there is nothing. I confirmed there is power to the unit.
Replacement parts for KUDS40FVPA models | AppliancePartsPros.com
Check that the unit is getting power.
Check the thermal fuse Item 5 in Section 2
If blown be sure to use the harness that comes with the replacement fuse.
Could also be a door switch is blown or not closing.
