Dishwasher continues to run with one minute showing
Brand:Bosch
**Model Number:**SHE43P12UC/56
Main Symptom:Continues to run
What happens & when:Dishwasher runs and washes dishes. The dishwasher continues to wash or rinse when the countdown times shows one minutes. Filters are clean and nothing in the trap. When the cycle is cancelled the water in the dishwasher will pump out to the sink/disposal.
Error Code (if any):None
Since the dishwasher is washing normally and drains properly when you cancel the cycle, you’ve already ruled out a clogged filter or a failed drain pump. The fact that it consistently stalls at 1 minute remaining usually means the control is waiting for a condition that it never sees before it will end the cycle.
The most common causes on this Bosch model are:
  1. Heating system issue (most common)
    During the final rinse, the control waits for the water to reach a target temperature. If the water never heats, the timer can remain at 1 minute indefinitely.
    • Start a Normal cycle and let it run for about 20–30 minutes.
    • Carefully open the door. The water should be very hot (around 120–140°F) and you should notice steam.
    • If the water is only lukewarm, the dishwasher likely has a problem with the heating circuit. This could be the heating element, high-limit thermostat, wiring, heater relay on the control board, or the control not energizing the heater.
  2. Check for stored fault codes
    This model can store diagnostic information that may point directly to a heating, temperature sensor, or circulation issue. If you’re comfortable entering the service diagnostics, I can provide the button sequence for your exact model.
  3. Temperature sensor (NTC)
    If the NTC temperature sensor is reading incorrectly, the control may think the water never reaches the required temperature, even if the heater is working.
  4. Circulation pump/heater assembly
    On many Bosch dishwashers, the heater is integrated into the circulation pump. If the pump is moving water normally but the heater portion has failed, the dishwasher can wash well but never complete the cycle.
A couple of questions that will help narrow it down:
  • Are the dishes hot and dry when the dishwasher gets stuck at 1 minute, or are they still wet and cool?
  • Does it do this on every cycle, or only on certain cycles such as Auto or Normal?
Those answers will help determine whether we’re dealing with a heating problem, a sensor issue, or a control board fault.
