Dishwasher/blinking light
My dishwasher doesn’t work. The “normal” cycle light blinks all the time. When I press other buttons they dont work either, Please help me.:confused:
Your model number does not come up, are you sure it is QU and not GU.
The following is for a GU unit.
Have you tried removing power from the unit for 10 minutes or so, to see if it will reset.
Could be that the normal key is stuck (closed).
To check it:
Unplug / remove power from the unit.
Remove the ribbon cable from the control board.
Measure at the ribbon cable using the 20,000 ohm scale.
Place the positive lead on P1-13 and the negative lead on P1-4.
It should measure infinite ohms.
When you press the button you should see the resistance drop.
