Dishwasher Acting Up
My G.e. Dishwashers Control Panel Dose Not Light Up And Will Not Show What Mode Its Running In,or Time,some Times It Wont Work For A Day Sometime Three Days And Some Times Will Not Work At All,something Going To Let Go How Do I Go About Repairing That Mane Panel,so It Shows Lenth Of Wash Heated Dry, Short Wash,upper Rack,pots And Pans And So Forth,
Thank You
Tony,
Here is the parts breakdown
Replacement parts for General Electric PDW8900L00BB Dishwasher | AppliancePartsPros.com
Got very lucky and was able to find a manual
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
I would try the following first as it sounds like a dirty/intermittent/loose connection
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
