Dishwaher keeps running when cycle is done
Hello. I have a Frigidaire AquaSurge with SpeedClean dishwasher (Model #FDB4315LFC0) that is 2 years old. All the cleaning cycles work fine, but when the cycles are done, the motor keeps running, and to make it stop, the dishwasher door has to be left open. Is this a motherboard gone bad, a thermostat gone bad, or something else?
At the end of the wash cycle, does the water drain out?
Yes, the water drains at the end of the cycle, but the motor or pump keeps running.
You probably have a stuck relay on the control board. I would replace the control board.AP3965268
I have the same problem. It’s telling me to replace the motor based on the water/service test. Giving me the error code hS which is bad hall sensor. I don’t know if I should replace the motor or the control board! Please help.
Thanks, gary!
Control board was the issue. Thanks for the reccomendation. I was going to change the motor(hall sensor). Local Parts store had the control board for $90. not bad!
