I have not. It seems very tight. If I try to pry it up, the force I have to use seems like the lever will snap. Do I just pull it out with a pair of pliers?
[quote=Gene;98369]Remove the outer door panel to see and access the dispenser. I hope it will make it easier.
Gene.[/quote]
I’m not sure what you mean? Does the broken latch come out by prying? And the new one sanp in place by reinserting it?
Or do you take the front cover off the dishwasher and manipulate the dispenser in some manner? Any photos or diagrams available?
Thanks for your help.
