A few months ago this unit started to leave what looks like soap residue on outside of dishes & grainy material on inside of cups, bowls. I had a repairman look at it & he cleaned it (I watched him , it didn’t seem very dirty) & said to try different soap etc. This didn’t help.
What are likely causes of this? I’d like to be informed before I get another repairman. Maybe even fix it myself if possible.
thanks
Wayne
There is an article about this in the link below that you can read what is happening and how to fix it.
Dishwasher is No Longer Cleaning – Film and Debris are Left on Dishes : ApplianceRepairLesson.com
Good luck.
That article just says to use a phosphate addtive, but I don’t see why it just recently started having problems.
because the detergent companies just recently had to change their formulas not even 3 months ago.
I took it apart & noticed this part called the ACCUMULATR has a thin plastic membrane that has become unglued along one of the 6 sections. could that be causing the problem?
Part Details - WHIRLPOOL ACCUMULATR, part number: AP4362441
In case anyone is interested, I fixed it temporarily with superglue & seems to work now. Will probably order a replacement part.
