Dish washer
dishwasher is draining as soon as it fills, so within 5 minutes it is empty.
A model number may help others help you.
Also did it used to work OK?
I believe the model is 8524569. and yes it worked.
Sorry but that does not look like a Kitchenaide model number.
Usually they start with several letters.
Model Number Locator
Sorry,
Model number is KUD101ILBS2
I think your model should be KUDL01ILBS2 not KUD101ILBS2
Info below is for the KUDL
Replacement parts for WHIRLPOOL KUDL01ILBS2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Check that the drain motor Item 17 in Section 8 is getting power when it should not.
If it is then your control board is probably shot.
