will not start when start button is pressed has voltage to door switch
Replacement parts for KENMORE 66513443K900 | AppliancePartsPros.com
Could be that the thermal fuse on/near the control board is blown.
Check it with a meter.
If blown be sure to use the new harness that comes with the replacement.
got my new part in today installed it so far so good thank you very much for the help and the part was cheap from you guys thanks william morgan
[quote=denman;646246]Here are your parts
AP3115186[/quote]
replaced so far so good thanks a lot william
