Dish washer will not drain
I own a Ge Triton profile .The dish washer run the cycle fine ,but the water will not drain.I think i need a new pump Part #AP2039463 But it did not say if this was a drain pump or a pump to bring water in the sprinkler heads? Can you help me find the part i need .Thanks, Timbosch.
Did you check to see if drain hose was unclogged? Take it off of pump and blow it out back into sink drain.
