When I load my dishwasher and turn it on, sometimes it may come on at that exact time. Others times I may turn it on and it does not do anything for days on end. What part may need to be replaced?
Hi Dwayne,
Does the “cycle on” light comes on every time?
Does the dishwasher malfunction on any cycle?
the cycle light only comes on when works
[quote=Gene;17302]Hi Dwayne,
Gene.[/quote]
Hi Dwayne,
You did not answer on the above question.
once it comes on if it does it works find through all the cycles
when the cycle light is on the dishes washer works when turn to the on position but most the time in the on position or run the cycle won,t come on that,s on all settings
Sorry, you probably did not get my question right. I meant cycles chosen on the selector switch on the left side.
my dishes washer malfunction on all cycle when it,s not working.
Hi Dwayne,
The first thing I would check is the door switch (#803 on the break down diagram) and wires.
If there is nothing wrong then the problem is a bad timer.
The part number for the door switch is [COLOR=#800080]AP2038824[/COLOR]
The part number for the timer is [COLOR=#0066cc]AP2039749[/COLOR]
Here are the break down diagrams for the GE dishwasher Model EDW1500G00BB
