I pulled the motor cover to reveal the sidewinder motor. The motor is spinning clock-wise. I reassembled it and, like I said before, all I"m getting out of the spray arm is a trickle. There’s plenty of force coming from the pump itself. Still don’t know what’s the problem.
I found the problem there was a button or cap of some sort lodged in the spout that feeds the sprayer arm Works like a champ now The impeller vanes are cupping the water in the clock wise direction thanks for all you help
