Brand:
Frigidaire
Model Number:
DGHF2360PFA
Main Symptom:
Ice dispenser auger motor runs continuously.
The metal drive shaft at the back of the freezer (which turns the corkscrew/auger in the ice bin) spins constantly whenever the dispenser door is closed, even when the dispenser lever is not being pressed. The auger immediately stops when the refrigerator door with the dispenser is opened. Issue started while actively dispensing ice. Removing the front dispenser display/control panel did not stop the motor from running.
None displayed.
Verified auger stops when freezer/dispenser door opens.
Removed dispenser display/control panel — auger motor still runs continuously.
Ice bin removed for observation of drive shaft spinning.
No parts replaced yet.
(To be added)
