Detergent dispenser won't open during wash
Dishwasher detergent dispenser wont open during wash. Sometimes it is wet & hard today it was dry . No tall utensils were in front to dispenser.
I cannot find info on a TS02 but there is a TSQ2.
Please check your model number.
Could be the solenoid or wax motor which opens the door is burned out.
