Defrost won't run on Whirlpool Refrigerator
Brand: Whirlpool
Model Number: WRS325SDHB04
Main Symptom: DEFROST WON’T RUN
What happens & when: Will not go into defrost and freezes up. Had repair man out and he said only 77 volts was coming up to the defrost and it should be 120 volts. He recommends replacing the electronic control board on the back of the fridge that would send the power to the defrost to run. He also recommends replacing the defrost thermistor on the evaporator coil to be safe because they go out a lot and mine he could not test because I had the fridge de-iced and turned off. I’m looking for conformation before I at least order the control board. Please help!
I would agree with the tech on this one. The bi-metal on the evaporator opens at a warm temperature. If the coils are defrosted, there is not a proper way to test the thermostat, go ahead and replace it. If you want to watch the system for a while to see if the new thermostat fixed the problem, you can and then order the board. It’s up yo you .
I would love to be able to just replace the defrost thermostat and not the control board. Does the thermostat send a notice to the control board to send the power to defrost or does the power come from the control board and then the defrost thermostat tell it to run or not?
If you have the ability to do this here is your tech sheet.
Whirlpool WRS325SDHB04 Refrigerator Tech-Sheet-W11212322.pdf (826.8 KB)
Troubleshooting Guide - W11503396.pdf (4.7 MB)
The thermostat opens up on a temperature rise, regardless if there is still voltage going to the element. it is sometimes referred to as a terminator, it terminates the heat to keep it from getting too hot.
No Bi-metal on this refrigerator!
My bad, it is a thermal fuse and is part of the evaporator wire harness, W11545823 Wire Harness | Genuine Whirlpool OEM In Stock
Thanks for the help. I can’t find a separate access panel on the back of my fridge for the electronic control board like I see in videos. Where would that control board be located on my model? I can’t find any videos on my model fridge on the website.
Also, are you saying I would need the wire harness mentioned above instead of the defrost thermistor part number WPW10384183 ?
In the back, where the compressor is located, there is a box with the main control in it. You will need to remove the back cover. If you need to replace the thermal fuse on the evaporator, you would need the wire harness that I referenced; it has the thermal fuse in the harness. The thermistor you are looking at is not the same as the thermal fuse that attaches to the evaporator coil.
