Dryer will not start, I replaced the rotary start switch, it worked for 3 times, then quit again. Should I replace the resistor next or could it be something else? could you give me a ballpark figure to repair this machine?
Thank you
kagey5148
Blower & drive assembly replacement parts for General Electric DDE7900SBLWW Electric dryer | AppliancePartsPros.com
Here is a good link. Check out #28 which may help some with the wiring
http://www.applianceaid.com/ge-dryers.html
Hopefully you have the wiring diagram, it is usually in the control console.
I will not be able to find the diagram for this unit on the net as GE likes to keep all tech info a secret. Guess it keeps their techs busy.
[COLOR=Blue]Should I replace the resistor next or could it be something else?[/COLOR]
No, as far as I know the resistor has nothing to do with starting the unit.
[COLOR=Blue]could you give me a ballpark figure to repair this machine?[/COLOR]
No idea till you figure out what the cause is.
First check that the unit is getting the correct power.
Next high on the list would be a broken belt as the unit does have a belt/idler switch which probably cuts power to the motor.
Then perhaps a thermal fuse if there is one in the motor’s circuit.
