The damper door on my 02 Frigidaire was stuck open. I took it apart and shut it and now it wont open. Do i need to replace to control box and damper or could the problem be somewhere else? Thank you for you response.
Parts for Frigidaire FRS26HF6BB0 Refrigerator - AppliancePartsPros.com
Here is a better copy of the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389607.pdf
Since it will not open or close odds are that you need a new damper assembly.
You could check the fresh food thermostat with a meter to make sure that it is OK.
Thank you i will look in to it.
