DACOR Refigerator not cooling below 52 degrees, freezer works great
Brand: DACOR
Model Number: DYF42SBIWR
Main Symptom: Freezer works great, Frig won’t get below 52 degees. Replace fan, same symtoms. Main display show 52, and my thermometer reads same.
What happens & when: always
Error Code (if any): n/a
Parts or tests already tried: fan
Thanks for the details! Since your Dacor DYF42SBIWR freezer is cooling properly, but the refrigerator stays around 52°F, I’d concentrate on the airflow and cooling components serving the refrigerator section rather than the compressor.
The fact that the display and your thermometer both show 52°F is helpful. It tells us the refrigerator really is warm, rather than just displaying an incorrect temperature.
Since you’ve already replaced the fan and nothing changed, I wouldn’t recommend replacing another part just yet.
Here’s what I’d check next
1. Check for frost buildup. Look along the rear interior wall of the refrigerator and freezer compartments. Do you see any frost or ice buildup? A frosted-over evaporator can restrict airflow and prevent proper cooling.
2. Verify the new fan is actually running. Even with a new fan installed, we need to make sure it’s receiving power and moving air. Depending on the fan’s location, you may need to hold the door switch closed to check its operation.
3. Check the refrigerator evaporator. This model may have a separate refrigerator evaporator and fan assembly. If the refrigerator evaporator isn’t getting cold, replacing its fan won’t correct the problem. An evaporator frost-pattern inspection can help distinguish an airflow or defrost problem from a refrigerant-flow problem.
4. Check the thermistor. A faulty temperature sensor can cause the control board to regulate cooling incorrectly. However, because your display agrees with your thermometer, I wouldn’t make the thermistor my first suspect.
I have three questions:
  1. Which fan did you replace? Was it inside the refrigerator compartment, inside the freezer, or underneath the refrigerator near the compressor?
  2. Is there any frost or ice buildup on the back wall inside either compartment?
  3. Do you hear a fan running inside the refrigerator when you hold the door switch closed?
Based on your answers, we can narrow this down to an airflow problem, a defrost issue, or a problem with the refrigerator’s cooling system.
My main concern is that the refrigerator evaporator may not be cooling properly. If that’s the case, replacing fans or control boards won’t solve the problem. I’d like to rule that out before you spend any more money on parts.
Also, at 52°F, the refrigerator isn’t maintaining a food-safe temperature, so I’d move perishable foods to another refrigerator until it’s repaired.
I replaced fan inside the refrigerator compartment
Thanks for confirming! Since you’ve already replaced the fan inside the refrigerator compartment on your Dacor DYF42SBIWR, and the freezer is cooling properly but the refrigerator won’t get below 52°F, I wouldn’t replace another fan just yet.
The next step is figuring out whether the refrigerator is getting enough cold air and whether the control system is correctly regulating the temperature.
Here’s what I’d check next:
1. Check for airflow. With the refrigerator running, hold the door switch closed and see whether you can feel air moving from the refrigerator’s air vents. Some fans only operate when the door is closed.
2. Look for frost buildup. Check the back interior wall of the refrigerator and freezer for unusual frost or ice. Ice buildup around an evaporator can restrict airflow even when the fan is working.
3. Check the door gasket. Make sure the refrigerator door is sealing completely and warm air isn’t entering the compartment.
4. Check the temperature sensor. A faulty refrigerator thermistor can send incorrect temperature information to the control board. We can check its resistance with a multimeter once we identify the correct sensor and its specifications.
One important detail: This model uses a cooling duct at the rear of the refrigerator compartment, so checking for blocked vents or ice buildup is particularly important.
Encompass Research+1
I have two questions that will help narrow this down:
  1. When you replaced the refrigerator fan, did you notice any frost or ice buildup behind the interior back panel?
  2. Is the new fan actually running when the refrigerator is calling for cooling?
Those answers will help us determine whether to investigate a defrost problem, fan control issue, or refrigerator cooling system problem next.
Also, since the refrigerator is staying around 52°F, please move perishable food to a properly cooled refrigerator until this is resolved.
