D.W. Motor failed to start
Out of the blue. Motor failed to start, as if the capacitor was shot or the mechanism is impeded. It just hums.
When I push cancel, I can hear water being pumped out, although I can’t see any water if I open the door.
Thanks for any help. I’m ready to tear into it.
all I have is the schematics…
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208530866.pdf
Thanks for the pics. Turns out it was the washer impeller which hard deconstructed and jammed the motor.
